I just installed a HomeEasy HE203 in wall dimmer switch. When I use the switch to turn it on correctly but when switch using vera lite it turns on but very dimly. Any ideas
Please try with the RFXCOM test application named RFXmngr. If you have the same behaviour, please contact RFXCOM. If not, come back to me.
I have the same problem. It briefly flashes full then goes dim. It works fine with rfx
i just tried changing it to a dimmer and now is repeatedly goes from dim to full and back. i think this needs to be set up properly. what would the hex code be for tthese
i think i fixed it. contact me emcrobert_at_gmail.com if you want the solution. it involves changing the xml file
If the change concerns one file of the plugin, please provide to me the correction so that I can include it to the plugin.
I have only just got my RFX today but it seems to up and running.
I only have one homeeasy plug at the moment while the other devices turn up.
How do get it to function?
I’ve gone to create a device, and put in random (at this stage) numbers into the group I’d and hex code, and I can create a device in Vera.
Setting the homeeasy in learn, and it flashes. Operating the switch in Vera though doesn’t do anything.
Am I doing it wrong somehow?
Maybe in learn mode the plug and the RFXtrx need to be very close.
That is the case for certain other protocols like Chacon.
thetwc,
LWRF modules can have up to 6 remotes paired.
Try this: reset the LWRF module so that all remotes are removed and pair the VERA device.
