HomeBuddy on my Android phone has started displaying a door sensor and a dimmer switch with temperature and thermostat values. I am using UI4 and 1.1.1047 on Vera2. Everything on the mios dashboard looks normal. Is anyone else experiencing this? I’m going to run a network ‘heal’ tonight to see if that clears things up. ??? ???
It seem’s to be a common problem and has been discussed in detail at the following link
http://forum.micasaverde.com/index.php?topic=4403.0
m0jon
Yes, I knew about the Schlage Lock reporting temperature thread. I even commented on that. It seems for my installation, that several devices other than the schlage lock have gone off track, one dimmer, one door sensor, etc…
