NOTE: Beta is now closed. Please get install Home Buddy v0.28 from Google Play.
Hi all!
I know it’s been forever since the last release. I’ve been really busy the past months but I did put in some time during the weekends to rewrite Home Buddy from the ground up. I think it’s almost ready for prime time (just a few more bugs to squash and some missing features – ie camera integration), but I thought I’d release an early beta for any brave souls who would like to give it a go and provide feedback. You can download it using the link below:
- Updated Sat 12 May 2012 12:01:48 PM EDT
[glow=red,2,300]NOTE: After updating, if you experience force closes on startup, please try to uninstall then reinstall!!![/glow]
Note that this will replace your current version of Home Buddy. If you want to revert back to 0.27, you’ll need to uninstall then reinstall from Market or SlideMe.
The most significant changes in this release are the following:
- Data Persistence: all data is now stored locally in a database for quick startup and access/control
- Revamped UI: now uses ViewPager and an ActionBar, and incorporates controls in the list instead of a separate dialog
- Support for multiple Vera units
- Favorites
- New setup procedure
- New Auto Local algorithm
- Many performance enhancements
I hope you all think that this release was worth the wait. As always, all feedback is welcome and greatly appreciated. I’m looking forward to hearing from you!
EDIT Mon 12 Mar 2012 09:02:14 PM EDT:
- Added favorites
- Added option to bypass refresh prompt
- KNOWN BUG: last item in the device list needs to be tapped twice to collapse. very annoying! still looking for a fix.
EDIT Mon 12 Mar 2012 10:41:09 PM EDT:
- Fixed the bug where last item in the list needs to be tapped twice.
EDIT Sat 24 Mar 2012 09:54:02 PM EDT:
- Added camera streaming
- Speak a scene (experimental)
- Now restores room expand/collapse state after full refresh
- Fixed WindowCovering, DoorSensor, and SmokeSensor
- Some performance optimizations
EDIT Sun 25 Mar 2012 09:39:42 PM EDT:
- Auto-Refresh (experimental - configure interval in setup)
- Caddx, CurrentCost, SmartSwitch support
EDIT Tue 27 Mar 2012 03:17:04 PM EDT
- Auto-local bugfix
- Now toasts an error on streaming errors
EDIT Fri 06 Apr 2012 04:11:17 PM EDT
- Auto-local bugfix
- Updated icons
- Dims device icons with text
- Feedback for camera streaming errors
- Scale camera still image to fit width
- Concord Alarm support
EDIT Fri 13 Apr 2012 11:40:51 PM EDT
- Elk Alarm Panel Support
- Changed Thermostat Fan Commands to a spinner
- Removed fade in/out effects as they didn’t play nice with the Expandable list
EDIT Tue 17 Apr 2012 11:15:04 PM EDT
- Styled buttons to make active state more prominent
EDIT Thu 19 Apr 2012 06:58:51 PM EDT
- Now only shows set point controls for active user operating mode
EDIT Sat 21 Apr 2012 12:46:20 AM EDT
- Fixed camera streaming on ICS
- Fixed some styles
- Added vibration on error
EDIT Fri 27 Apr 2012 07:28:51 AM EDT
- Reversed window covering open/close labels
- Room names can now go to 2 lines (in case of really long names)
- Variable Container support
EDIT Sat 28 Apr 2012 10:34:18 AM EDT
- Updated to UI5 icons
- Danfoss Living Connect support
- Fixed Variable Container
EDIT Sun 29 Apr 2012 11:37:16 AM EDT
- Update Window Covering implementation to match Vera’s
- Added Filipino, German, and Greek (initial) locales
EDIT Mon 30 Apr 2012 06:10:53 PM EDT
- Speak-a-Scene enhancements/bugfixes
- Wake on LAN plugin support
EDIT Sat 05 May 2012 03:21:35 PM EDT
- Added status icon to Door Lock when unlocked and optimized virtual switch to use the same status icon mechanism
- Initial Dutch translations
EDIT Mon 07 May 2012 11:19:17 AM EDT
- Added Default Tab option
EDIT Mon 07 May 2012 02:43:00 PM EDT
- Fixed force close for users upgrading from 0.27
EDIT Mon 07 May 2012 06:57:46 PM EDT
- Completed Dutch translations
