Just so you know, I’m a total Vera noob and I just got my veraedge. I’m trying to connect it to a powermax pro partition using the plugin from MiOS, but it doesn’t work(can’t detect device and reading panel settings issues), I read that I have to manually upload rev.86 files. I have the files but how do I upload them? Do I uninstall the plugin first? Please help, I bought the Vera mainly for this plugin.
Hi
Yes, Uninstall the plugin.
Then go to
APPS > DEVELOP APPS > LUUP FILES > DRAG AND DROP individual files…
see screenshot
then this will reload you vera unit…
once this is complete go to…
APPS > DEVELOP APPS > CREATE A DEVICE > Paste in D_Powermax.xml as device filename
see screenshot
click create device
and reload will happen.
The final step depends on how you are connecting the Vera to the Panel…
Serial or ethernet?
If serial, then you need to set the “Serial Port configuration” under develop apps
otherwise you need to set the IP address and I think port in the device settings for the panel
