Have a camera that I was given but don’t have any user manuals. I’m trying to identify what the image URL and username and password are so I can try to add it to Vera.
However channel is likely to be main and sub streams.
Maybe try 1 or 2 as the channel or 01 or 02 or 101 or 102 etc.
And the Vera add camera wizard allows you to specify the user and password in form fields. So you shouldn’t need to have the user and password in the actual URL.
Here’s the response I got from Truen who make the camera. So I guess I can’t use this camera?
"For your inquiry, we cannot provide address.
RTSP is not available because of the server and encryption operation when it is connected with the server.
I’m sorry for not giving you a positive answer."
I recommend Blue Iris. It works with almost any camera and you can connect it Vera to have Vera arm/disarm Blue Iris, and use the cameras as motion sensors in Vera. I set it up years ago so search the forum on how to set it up.
