Hoping you guys can help me understand why the below LUA (2 separate LUA in separate scenes) are causing the startup error.
thx
local vacation_mode = luup.variable_get(“urn:dcineco-com:serviceId:MSwitch1”,“Status7”,224)
local aaron_traveling = luup.variable_get(“urn:dcineco-com:serviceId:MSwitch1”,“Status7”,223)
– Do NOT Run when Vacation or Aaron_Travel virtual switch is on
if (vacation_mode==“1” or aaron_traveling==“1”) then
return false
function resetSensor (device)
local SECURITY_SENSOR_SERVICE =“urn:micasaverde-com:serviceId:SecuritySensor1”
luup.variable_set (SECURITY_SENSOR_SERVICE, “Tripped”, 0, device)
resetSensor(271) – Main Room Motion Vista 20p
resetSensor(149) – Dining Room Motion
resetSensor(552) – Entry Motion multi
resetSensor(209) – Garage Motion 2
resetSensor(164) – Garage Motion
resetSensor(567) – Living Room multi
resetSensor(155) – Media Room Motion
resetSensor(579) – Motion multi 1
resetSensor(151) – Mudroom Motion
resetSensor(150) – Office Motion Sensor
resetSensor(210) – Patio Motion Sensor
resetSensor(163) – Playroom Motion Sensor
resetSensor(571) – Deck Motion multi
[quote=“rlmalisz, post:2, topic:195136”]Just a stab, but shouldn’t both have a “return true” at the end?
–Richard[/quote]
Thx for the help. I’m not 100% clear when ‘return true’ is needed.
Just one at the very end of each code set - Like below?
return false
return true
