Help On Setting up Scene
Hello everyone! I’m new here and to Vera. I’m trying to set up what seems like to me should be a simple scene. Here is what I want to do:
A “Come Home” scene that does the following when activated:
Turn on HVAC.
If sunset (in other words – dark) turn on a set of lights. If not dark then don’t turn them on.
The part I am having problem with is the condition on the lights. While I can create a sunset scene and have it turn on the lights I don’t see how NOT do it when no one is home.
I read the Wiki pages on this that I could find, but all their examples did not cover this type of conditional logic.
Can anyone explain how that is done?
I feel real stupid about not being able to do that, particularly since I am a software developer, so you would think it should be easy to do, but there is some serious lack of documentation. Some of you mentioned a user manual. Is that the Wiki documentation or is there something else? All I got was a 4 page “Quick Start Guide”.
Rolf
read the post a few down called:
Question for MCV: Luup/Lua?
To put it briefly, conditional logic requires writing code using LUA.
It’s very simple LUA :slight_smile:
But keep in mind LUA version it’s still “under construction”, so if you’re willing to play with it don’t get upset with bugs…
Okay, I’ll Look at LUA after it is officially released. I hope some simple conditionals can be added to the standard Vera interface using LUA in the background. In the mean time i solved my problem by creating two scenes, one for coming hope during daytime and another for nighttime.
Rolf
