I managed to get my Vera3 back as Master and started over.
Problem stays that I still can’t restore the backup file.
Any ideas?[/quote]
I did mine from scratch as upgrading to a z-wave plus chip never seemed straight forward for easy to do. I slowly moved over devices and plugins as I had time to.
I only miss one or two devices. Not easy to count because names are missing as well as the config files for sensors other than motion sensors. Plus some unwanted children devices are appearing.
My problem still is that the backup file can’t be uploaded. ???
After several failed attempts to restore the backup, I noticed that the tar file was quite big. Within the container was only one bigger file. That was ergy_cache_paired_devices.conf. Since I don’t use the energy control, I deleted the file, packed the etc folder and uploaded it again.
Vera was a bit unhappy and gave an unspecific error warning but a few minutes later my new Veraedge looked like Vera3. ;D
