Welp, another sudden moment the hub died. It’s not starting properly, I’m getting the following in logfiles:
ha-extensions_manager.log:
2023-02-16 18:35:14.545956 INFO : Try to register plugin: ezlo.philips_hue
2023-02-16 18:35:14.547237 INFO : Registering plugin: ezlo.philips_hue-1.0.27
2023-02-16 18:35:14.547850 INFO : Addon started: lua-1.0.2193.2
2023-02-16 18:35:14.548135 INFO : Plugin started: ezlo.philips_hue-1.0.27
2023-02-16 18:35:14.555626 ERROR: CoreDRemoteInterface::ensureGateway::sendRequest: Internal operation error
2023-02-16 18:35:14.555981 ERROR: init: GatewayPlugin: fail to init the 'gateway' plugin: fail to register the gateway
2023-02-16 18:35:14.559677 ERROR: Exception 'St16invalid_argument' was caught:parse error - unexpected '
2023-02-16 18:35:14 ERROR : Standard exception was caught(N11HubPlatform8Services8TaskLoop13TaskExceptionE): TaskLoop: uncaught exceptions
2023-02-16 18:35:14.564656 INFO : Addon stopped: lua-1.0.2193.2
ha-zwaved.log shows no zwave activity.
ha-restart shows:
**** extensions_manager Restarted at Thu Feb 16 18:38:03 CET 2023
**** extensions_manager Restarted at Thu Feb 16 18:38:05 CET 2023
**** extensions_manager Restarted at Thu Feb 16 18:38:06 CET 2023
**** extensions_manager Restarted at Thu Feb 16 18:38:08 CET 2023
ha-uid.log:
2023-02-16 18:37:48.404263 INFO : Received new command: hub.gateways.list
2023-02-16 18:37:48.416950 ERROR: Processing NMA message: unknown std::exception(St16invalid_argument): parse error - unexpected '
2023-02-16 18:37:48.417532 INFO : Received new command: hub.network.get
2023-02-16 18:37:48.417730 INFO : Process COMMON command: hub
2023-02-16 18:37:48.421244 INFO : Received new command: hub.favorite.list
2023-02-16 18:37:48.422997 INFO : Received new command: hub.custom.nodes.list
2023-02-16 18:37:48.432765 INFO : Received new command: hub.features.list
2023-02-16 18:37:48.436020 INFO : Received new command: hub.scenes.expressions.list
2023-02-16 18:37:55.689847 INFO : Received new command: hub.scenes.block.data.list
ha-luad.log:
Request all device values for device_id: 634d5789129e0f123872cac7
2023-02-16 18:29:59.214719 INFO : LuaAddon: a script: HUB:zigbee/scripts/startup has been executed successfully
LUA: Attribute value updated: node_id: 49156
2023-02-16 18:29:59.277956 INFO : LuaAddon: a script: HUB:zigbee/scripts/events/zigbee/events_handling has been executed successfully
2023-02-16 18:29:59.364628 INFO : LuaAddon: a script: HUB:zigbee/scripts/events/zigbee/events_handling has been executed successfully
LUA: Attribute value updated: node_id: 14495
2023-02-16 18:29:59.393197 INFO : LuaAddon: a script: HUB:zigbee/scripts/events/zigbee/events_handling has been executed successfully
2023-02-16 18:29:59.419216 INFO : LuaAddon: a script: HUB:zigbee/scripts/events/zigbee/events_handling has been executed successfully
2023-02-16 18:30:29.418261 ERROR: plugin has no permissions to use the required module native_plugins_utils
2023-02-16 18:30:29.418642 ERROR: Couldn't execute script 'HUB:zigbee/scripts/helpers/scripts_preload: Fail to load native_plugins_utils functionality
stack traceback:
=[C]
=[C]
2023-02-16 18:30:29.419068 ERROR: LuaInterpreter: Couldn't run a Lua code: ?:-1: attempt to index a nil value (field 'hubplugins')
stack traceback:
2023-02-16 18:30:29.419309 WARN : LuaAddon: a script: HUB:zigbee/scripts/events/zigbee/events_handling has been terminated abnormally
2023-02-16 18:31:14.756868 INFO : ezviz: [Migration] Plugin is up-to-date
2023-02-16 18:31:14.757368 INFO : LuaAddon: a script: HUB:ezviz/scripts/migration/execute_migration has been executed successfully
2023-02-16 18:31:14.763343 INFO : ezviz: Starting up...
2023-02-16 18:31:14.775169 INFO : ezviz: Update settings files signatures
2023-02-16 18:31:14.786944 INFO : ezviz: Create socket for UDP broadcast discovery
2023-02-16 18:31:14.790217 INFO : ezviz: Create UDP socket
Seems something very fundamental has gone wrong. Has there been a firmware push today?
