Hi, I have this reactor, that the last few days, has started to trigger, I have change nothing, in the past few days.
please note that the state “home/night” is false, as I not home, and have not been home the last 48 hrs. (but it still triggers), so “away=true” for 48 hrs. ![]()
*************************************************** REACTOR LOGIC SUMMARY REPORT ***************************************************
Version: 3.5 config 20017 cdata 20045 ui 20045 pluginDevice 884 LuaXP 1.0.1
System: Vera version 1.7.4970 (7.31) on Sercomm G450 ID 36 (Vera Plus); loadtime 1585898984; systemReady 1585899011; ALTUI v2.49; Lua 5.1; JSON dkjson 1.2; UnsafeLua=1
Local time: 2020-04-03T09:37:44+0200; DST=1; Storvorde, North Denmark Denmark; formats %d/%m/%Y %H:%M:%S
House mode: plugin 2; system 2; tracking on
Sun data: {}
Geofence: not running
Reactor Auto varme B (#931)
Version 19082.6 02/29/20 17:34:41
Message/status: Not tripped
Condition group "Reactor Sensor 4" (AND) false as of 09:30:07 <root>
&-F-housemode in 1,3 [2 at 09:30:07; F/F as of 09:30:07/09:30:07] <condcm0sn42>
&-T-service Master bedroom - Tem (20044) urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature <= 19.0; output latching [15.8 at 09:30:07; T/T as of 09:30:07/09:30:07] <condcm0son6>
&-F-service Soveværelset (44) urn:upnp-org:serviceId:TemperatureSetpoint1_Heat/CurrentSetpoint <= 5; output latching [16.00 at 09:30:07; F/F as of 09:30:07/09:30:07] <condcm0zes1>
&-T-service Window bedroom (720) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 0 [0 at 09:30:07; T/T as of 09:30:07/09:30:07] <condcm0sqfe>
&-T-service Door Master Bedroom (862) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 0 [0 at 09:30:07; T/T as of 09:30:07/09:30:07] <condfwjhx55>
&-F-trange bet ,,,21,0,,,,8,0 [1585899007 at 09:30:07; F/F as of 09:30:07/09:30:07] <condcm0xpou>
Activity root.false
Device Soveværelset (44) action urn:upnp-org:serviceId:TemperatureSetpoint1/SetCurrentSetpoint( NewCurrentSetpoint="5" )
Run Lua:
1: luup.call_action('urn:richardgreen:serviceId:VeraAlert1','DeviceNotification', {Msg='Auto varme sluk', Name='Auto varme sluk', Description='Auto varme sluk', DeviceID=0, HouseModeMask=undefined, Service='', Variables='', Recipients ='cokeman0'}, 443)
2: return true
Activity root.true
Device Soveværelset (44) action urn:upnp-org:serviceId:TemperatureSetpoint1/SetCurrentSetpoint( NewCurrentSetpoint="19.5" )
Run Lua:
1: luup.call_action('urn:richardgreen:serviceId:VeraAlert1','DeviceNotification', {Msg='Auto varme tændt', Name='Auto varme tændt', Description='Auto varme tændt', DeviceID=0, HouseModeMask=undefined, Service='', Variables='', Recipients ='cokeman0'}, 443)
2: return true
Events
2020-04-03 09:30:06: Reactor startup (Luup reload)
2020-04-03 09:30:06: Starting (Luup Startup/Reload)
2020-04-03 09:30:07: Condition condcm0sn42 test state changed from (nil) to false
2020-04-03 09:30:07: Condition condcm0sn42 evaluation state changed from (nil) to false
2020-04-03 09:30:07: Condition condcm0son6 test state changed from (nil) to true
2020-04-03 09:30:07: Condition condcm0son6 evaluation state changed from (nil) to true
2020-04-03 09:30:07: Condition condcm0zes1 test state changed from (nil) to false
2020-04-03 09:30:07: Condition condcm0zes1 evaluation state changed from (nil) to false
2020-04-03 09:30:07: Condition condcm0sqfe test state changed from (nil) to true
2020-04-03 09:30:07: Condition condcm0sqfe evaluation state changed from (nil) to true
2020-04-03 09:30:07: Condition condfwjhx55 test state changed from (nil) to true
2020-04-03 09:30:07: Condition condfwjhx55 evaluation state changed from (nil) to true
2020-04-03 09:30:07: Condition condcm0xpou test state changed from (nil) to false
2020-04-03 09:30:07: Condition condcm0xpou evaluation state changed from (nil) to false
2020-04-03 09:30:07: Group Reactor Sensor 4 test state changed from (nil) to false
2020-04-03 09:30:07: Group Reactor Sensor 4 evaluation state changed from (nil) to false
2020-04-03 09:30:07: Launching Reactor Sensor 4.false activity
2020-04-03 09:30:07: Launching scene/activity root.false
2020-04-03 09:30:07: Deferring scene execution, system not ready (root.false:1)
2020-04-03 09:30:07: Changing RS tripped state to false
2020-04-03 09:30:12: Starting "root.false" group 1
2020-04-03 09:30:12: ERROR: Using uninitialized global variable nil
2020-04-03 09:30:12: Activity "root.false" finished
Devices
ZWave (1) urn:schemas-micasaverde-com:device:ZWaveNetwork:1 (19/0); parent 0; plugin -; mfg model ; dev D_ZWaveNetwork.xml impl
Door Master Bedroom (862) urn:schemas-micasaverde-com:device:DoorSensor:1 (4/1); parent 1; plugin -; mfg Aeotec model ZW120; dev D_DoorSensor1.xml impl
Master bedroom - Tem (20044) urn:schemas-micasaverde-com:device:TemperatureSensor:1 (17/0); parent 20027; plugin -; mfg model ; dev D_TemperatureSensor1.xml impl
Window bedroom (720) urn:schemas-micasaverde-com:device:DoorSensor:1 (4/1); parent 1; plugin -; mfg Aeotec model ZW120; dev D_DoorSensor1.xml impl
Netatmo (20027) urn:akbooer-com:device:NetatmoMetric:1 (12/0); parent 0; plugin 4456; mfg model ; dev D_NetatmoMetric.xml impl I_Netatmo.xml
Soveværelset (44) urn:schemas-upnp-org:device:Heater:1 (5/2); parent 1; plugin -; mfg Danfoss model 014G0013; dev D_Heater1.xml impl
Watches
Device #862 Door Master Bedroom service urn:micasaverde-com:serviceId:SecuritySensor1 variable Tripped
Device #720 Window bedroom service urn:micasaverde-com:serviceId:SecuritySensor1 variable Tripped
Device #44 Soveværelset service urn:upnp-org:serviceId:TemperatureSetpoint1_Heat variable CurrentSetpoint
Device #20044 Master bedroom - Tem service urn:upnp-org:serviceId:TemperatureSensor1 variable CurrentTemperature
Device #884 Reactor service urn:toggledbits-com:serviceId:Reactor variable HouseMode
Device #931 Reactor Auto varme B service urn:toggledbits-com:serviceId:ReactorSensor variable cdata
Device #931 Reactor Auto varme B service urn:toggledbits-com:serviceId:ReactorSensor variable TestHouseMode
Device #931 Reactor Auto varme B service urn:toggledbits-com:serviceId:ReactorSensor variable TestTime
Special Configuration
UseReactorScenes = 1
Retrigger = 0
FailOnTrouble = 0
ContinuousTimer = 0
