Help! How to get Vera a primary controller again
Hi everyone,
I’m in trouble, the Aeon Stick of my Vera 1 got reprogramed somehow and was switches from Primary controller to slave. As I don’t have a primary controller now, I cannot include any devices any more.
Any suggestions are welcome including sending command to the stick directly. I just don’t know where to start. Anything I try with vera always results in the error messagage “Command failed: Not primary controller”.
Please help!
Thanks in advance
Umtauscher
very strange , I am having the same problem. I have a keyfob AEON lab but not sure this is the issue.
My Vera always results in the error messagage “Command failed: Not primary controller” when I try to go in exclusion / inclusion mode directly from UI5. and in the Battery mode, it seems I cant get a device included either
Yes that is strange. as I have a vera 1 with the aeonlab stick running firmware 1.1.1338.
Anyway is there at least someone out there who knows, if the primary/slave information is store in the dongle backup and if it can be restored from there?
TIA
Umtauscher
I verified, that at least the SUC information ist stored in the dongle.dump file which is part of the vera backup. So there seems to be a way to manipulate the primary/slave information of the z-wave dongle.
What I need now, is someone who is able to tell how the information ist stored or to help me find out. I am willing to patch the dump file, its only 16k so it might be possible.
There doesn’t seem to be a checksum because I was able to restore a patched dump into the stick.
Is there anyone willing to help?
[quote=“umtauscher, post:4, topic:177769”]I verified, that at least the SUC information ist stored in the dongle.dump file which is part of the vera backup. So there seems to be a way to manipulate the primary/slave information of the z-wave dongle.
Is there anyone willing to help?[/quote]
breaking news, MCV support fixed my unit. I am a satisfied customer ! and I could include my brand new Fibaro Wall Plug device ( which I could not before ).
“I’ve checked your unit and fixed it and you should be able to add your z-wave device now.
Can you please try to exclude and then re-include it and let me know how it goes ?
Thank you.”
Good for you! Congrats,
how did you contact them? I never had success getting proper help from support.
Cheers
[quote=“umtauscher, post:6, topic:177769”]Good for you! Congrats,
Cheers[/quote]
I did 2 things. from UI5 / Account / Tech Support , then create a ticket from there. I also went into http://getvera.com/support/ and logged a ticket there, just giving them the ticket ID of the first one I created.
On a Vera with UI5 and Z-Wave firmware 3.20, re-applying the [tt]Hack to convert 2.78 to 3.20[/tt] is known to force the Z-Wave chip into the primary role.
Unfortunately this isn’t supposed to work on a vera1, right?
Nope; that option is only in UI5, and implies firmware 3.20, which I thought was only for the internal Z-Wave chip. Or did Aeon release an update? (Still doesn’t help you with a Vera 1.) Did you try the restore-from-backup route?
Yes, I tried the AoenLabs update 3.07, but it didn’t change the slave mode.
My oldest backup is from 2010 but it already has PRI NO set. At least it sets the SUC mode so that I can add new devices, but I would try to patch the dump file to retain my network.
Still no luck, isn’t there anyone to help me to get the Aeon Stick to be primary controller again?
TIA
Umtauscher
Can you please submit a trouble ticket with tech support access enabled so we can check it out ?
Once it’s submitted and we will look into it asap.
Thanks.
Thank you very much for your reply.
I have did as you requested.
The output of my doing was:
Collecting logs…
. Network…
Done.
. System…
Done.
. Kernel…
Done.
. Zwave Status…
Done.
Compressing logs…
Compressed /etc/config /etc/firewall.config /etc/firewall.user /etc/lighttpd.conf /etc/lighttpd.users /etc/cmh /etc/cmh-ra /etc/cmh-lu /tmp/log /tmp/log.NetworkTroubleshoot /tmp/log.Rotate_Logs /tmp/log.SetupRemoteAccess /tmp/log.StartLuaUPnP /tmp/log.check_internet /tmp/log.cmh-ra-daemon /tmp/log.cmh-ra-daemon.gz /tmp/log.cmh_pnp.err /tmp/log.dmesg /tmp/log.fix_datetime /tmp/log.hotplug-usb /tmp/log.lighttpd_error /tmp/log.logread /tmp/log.no_internet /tmp/log.platform_init /tmp/log.sh /tmp/log.sysinfo /tmp/log.trouble_report /tmp/log.trouble_report_response /tmp/log.upgrade /tmp/logrotate_timestamp /tmp/log/cmh in /tmp/8210_troublereport.tar.gz
Submitting trouble report…
Successfully submited ticket:
Undefined variable 102447
Done.
I hope the error message at the end is not important.
Sorry, but I cannot give you full access to my vera because it would compromise the security of my entire network. So I hope the transfered files will be sufficient.
Cheers
Umtauscher
Just for the record
I managed to patch the dongle.dump file sucesslully myself and my vera1 is primary controller again.
Thanks to all who tried to help.
Cheers
Umtauscher
