Hi All,
Running Blue Iris plugin and cant get my camera to load in vera. i tried http://192.168.81.10:81/image/Cam3
and a few others but no luck
HELP
Hi All,
HELP
I have 4 cameras set up. I use http://192.168.81.10:81. It shows all 4 as a composite.
Hi Don,
Thanks but i still must be missing something. I am running Vera Plus with I17 and i am running the demo version of Blue Iris. I can view all cameras using the 192.168.81.10:81 in explore and typing in password. However is will not load up in Vera for some reason.
Can you print screen your setup? I am lost.
Tim
The only other information in addition to the IP address is the user name and password. Not sure why it is not working for you.
Do you have anonymous access enabled on Blue Iris? If not, try that.
Hi
Thanks for the reply, I am not really sure however I can access the Blue Iris from any other computer. How can i check to see if anonymous access enabled?
Thanks for your help.
Hi Again,
I can add the blue iris cameras as generic ip cameras, so it must be in the settings of my blue iris plugin. Any ideas?
In Blue Iris, click he cogwheel icon at the top left
Go to the Web Server tab
At the bottom, under Advanced.
Set Authentication to ‘NON-LAN only’ if not already set and make sure ‘Secure Only’ is unchecked
The reason for this is that the plugin does not support the specific authentication BI uses although most browsers do.
