Heatmiser Wired Network Thermostats
I have a Heatmiser system with wired PRT-N thermostats connected to a UH1 wiring centre and a Touchpad controller.
I would like to be able to monitor and perhaps eventually control the system remotely. I have installed the Heatmiser thermostat control app on Vera which says it connects via an RS422 interface and today I’ve got an an ethernet/wifi RS422 adaptor up and running on my network.
Problem is I can’t work out how to configure the Heatmiser App in Vera and/or the RS422 adaptor so that they can talk. It doesn’t seem to be a simple matter of IP address and port IDs.
Vera says “Can’t detect device”
Does anyone have this configuration working and can help me with set-up ?
Many thanks
