Hi Alan
Could you send me the heatmiser neo plugin. I don’t seem to be able to PM you
Fergus
Hi Alan
Fergus
Fergus - I’ll PM you.
Alan,
Quick one for you (hopefully), one of my NeoAir thermostats also has a floor probe but its reporting the floor temperature to vera rather than the room temperature. Is there a quick fix for this?
Attached screen grab of the variables, CurrentTemperature is FloorTemperature and really i would like RoomTemperature…
[SOLVED] - As soon as i looked at the variables i attached i see the TempSelect was set to Floor, changed to Room and that did the trick! Sorry for not looking properly before posting!
Hi ra carter,
I’ve ordered my UFH for the ground floor and have the wired Neo thermostats which will be installed in a couple of months. The 1st floor will also have wired thermostats but the loft floor will have wireless Neo thermostats.
Can I please confirm that your plugin etc will work for controlling both the wired and wireless version for each of my floors? Do I need to follow a particular setup because of the mixed wired and wireless (each floor will have only the one type not mixed wired and wireless on the same floor).
Thx.
The plugin was written to communicate with wireless Neo thermostats connected via a Neohub. I have no experience of wired Neo thermostats so I don’t know what their comms requirements would be.
Please could you send me the Neo app. Many thanks
racarter,
I queried your comment with Heatmiser directly and they replied “you can integrate with the neoHub over IP using the attached protocol document the thermostats all communicate to the neoHub so any neoStat wired or wireless is controlled via the app as it’s the hub that is integrated with.”
I have three floors with only the top floor being wireless and the ground floor and first will be wired.
Would you mind (eventually) helping me with this on the basis of what she has said?
Thanks.
Sure. When you’re ready just PM me your email address and I’ll send you the plugin files.
Alan
Hi Alan I have the latest heatmiser neohub controller and the neostats managing my UFH. I have recently bought a Fibaro HC2 and wondered if what you have developed would enable me to control my UFH from within Fibaro HC2? I cannot seem to PM you
The plugin was written specifically for Vera and would require a major rewrite to function on HC2.
Hi Alan,
Please could I get a copy of your Neo plugin?
Many thanks in advance
OliA - I’ve PMed you.
To avoid delays when requesting my Heatmiser Neo plugin please contact me via the webform at carter53.wordpress.com
Alan
