Good Afternoon
I done a heal report and i have attached copy of the report.
It shows no stars for any device but am not sure what its all about.
Rich
Good Afternoon
Rich
The posted report is based off of an automatic heal at 2:00am. Run the a manual heal operation and your heal report will be fully populated when it’s done.
Hi
I done another one and the results are below.
As I said, the report is now fully populated. Two devices with strong signals and three devices with weak or no signal.
You need more stuff!
[quote=“Z-Waver, post:4, topic:178385”]As I said, the report is now fully populated. Two devices with strong signals and three devices with weak or no signal.
You need more stuff![/quote]
This is what i dont understand
The downstairs thermostat is only about 1 metre away from veralite and upstairs one is about 7 metres away. There both closer than the controllers which are showing signal.
What make and model thermostats?
Are they controllable by Z-Wave/Vera or do they not work?
Is the 1 meter separation clear line of sight or are there walls/mirrors/file cabinets/refrigerators in between the two?
What flooring separates upstairs wood/concrete/steel joist?
Hi @Rich1983
Are those devices that are not showing any stars battery powered ?
I seem to recall my battery powered nodes are always blank on the report, as they are often asleep when being polled by Vera during the heal process.
