[quote=“ShawnInFL, post:16, topic:187865”]Hey Tom, thanks for your expertise on the subject. Yikes, I get the feeling if you can’t beat it, I don’t know that it will be beaten LOL The timeout issues sounds like the real deal and perhaps makes some sense of why the original poster, gsheremeta, seems to have resolved his issue by replacing his new version router with a much older router. Perhaps the timeouts are different. gGsheremeta mentions he felt it was an ipv6 issue. I could not conclude the same result as it didn’t work for me when I turned off ipv6 on my comcast router. This does provide a shred of hope though
Question, do you know of a router that would provide such capabilities? I would be more than happy to purchase a more robust router with additional options to resolve this issue once and for all.
Again, thanks for your input and contribution to the cause!![/quote]
Hey Shawn, I’m not sure what router to choose. What I would tell you when researching is get reviews of the software on the router and what you can actually do with it. That might tell you if you can increase the timeout before a port will close it’s connection.
DD-Wrt has cool software mods for the Buffalo routers which comes pre-loaded, that might do the trick.
I have the newer Comcast xfinity gateway. I was not able to find a way to turn off IPv6, how did you do it? Maybe I missed it?
I also thought about port forwarding GCM 5229, perhaps the rules of port forwarding on the Comcast router might have longer keep alives but I doubt it. If you explore this option make sure all IP’s on your home network get this forwarded or no one but you will get push messages.
Make sure you review the ports, I think it is 5229 only but might need to look that up again.
Push NOtification didn’t work because all it does is broadcast an intent. I configured Tasker to do this as well and proved with logs that it would send out the intent. But since there is no data to transmit it doesn’t use 5229 to transmit anything thereby not “waking” the port up.
Good luck, I still face the problem and would like a fix where I didn’t have to pay money.
