Good day,
I did a small tutorial on how to control the Hayward Superpumps without using their expensive controller modules.
The solution works fine and is versatile since you can control it via a local interface (Sonoff relay buttons), via a RF433 remote, via the web server located within the Sonoff module and finally from Vera using mqtt or any http request…
I am now working on controlling the drive module itself by bypassing completely the pump interface using a Geekcreit DT-06. That way, the solution will be neat as the module itself will be located within the pump itself !
[url=http://www.mrdindon.com/2018/11/controlling-your-hayward-superpump.html]http://www.mrdindon.com/2018/11/controlling-your-hayward-superpump.html[/url]
Let me know your comments ![]()
