hawking hrds1 question
Okay… dumb question… Installed a hawking hrds1 door sensor. Its working fine, but the green cog is always present. Is this normal? Everything else I have set up goes through with blue/red/green cogs but they always have disappeared after the device was configured. This is the first device I have seen that shows a green cog all the time. (UI-2, vera2)
should turn red when the door is open.
oops… found the answer… just had to RTFM
http://wiki.micasaverde.com/index.php/Device_Control_Status
Configure Paragraph:
This icon is “sticky”, meaning it will stay next to the device forever and doesn’t go away after 30 seconds like the others.
