Having trouble setting Azure (Vera3/Lite)
Hello,
I have the lest version in the market (2.0 and updated it again just in case). I think I did all that is needed to use Azure TTS - got the key, set it up in the settings with the location. But it just doesn’t work. Here is the bit from the log:
08 05/22/20 16:25:21.509 JobHandler_LuaUPnP::HandleActionRequest device: 354 service: urn:micasaverde-com:serviceId:Sonos1 action: Say <0x2e868680>
08 05/22/20 16:25:21.510 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=354 <0x2e868680>
08 05/22/20 16:25:21.511 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:Sonos1 <0x2e868680>
08 05/22/20 16:25:21.511 JobHandler_LuaUPnP::HandleActionRequest argument action=Say <0x2e868680>
08 05/22/20 16:25:21.512 JobHandler_LuaUPnP::HandleActionRequest argument Text=Test <0x2e868680>
08 05/22/20 16:25:21.512 JobHandler_LuaUPnP::HandleActionRequest argument Engine=AZURE <0x2e868680>
08 05/22/20 16:25:21.513 JobHandler_LuaUPnP::HandleActionRequest argument rand=0.09231901102880258 <0x2e868680>
50 05/22/20 16:25:21.523 luup_log:535: Sonos: Say action on device 354 text “Test” <0x2ade4310>
50 05/22/20 16:25:21.528 luup_log:535: Sonos: (tts debug) generate() engine Azure Speech Service text Test file /www/sonos/Say.354.mp3 <0x2ade4310>
50 05/22/20 16:25:21.529 luup_log:535: Sonos: (tts debug) AzureTTSEngine:say() host “francecentral.tts.speech.microsoft.com” payload “<speak version="1.0" xml:lang="en-US"><voice name="en-US-JessaRUS">Test” <0x2ade4310>
50 05/22/20 16:25:21.530 luup_log:535: Sonos: (tts debug) AzureTTSEngine:say() LuaSec “0.4”, using protocol “any” for request <0x2ade4310>
02 05/22/20 16:25:21.586 luup_log:535: Sonos: AzureTTSEngine:say() conversion request failed, invalid protocol <0x2ade4310>
02 05/22/20 16:25:21.587 luup_log:535: Sonos: (tts) engine Azure Speech Service error: request failed invalid protocol <0x2ade4310>
02 05/22/20 16:25:21.588 luup_log:535: Sonos: (tts) Engine “Azure Speech Service” produced no audio <0x2ade4310>
04 05/22/20 16:25:21.589 <0x2ade4310>
I guess the problem is that “invalid protocol” but have no idea what should I do about it. Any help, please!
Vera3/Lite? Or just older firmware?
You’re going to need to download a replacement L_Sonos_TTS.lua file and upload it to your system:
  1. Download the file by right-clicking on this link and choosing “Save link as…” from the context menu that pops up. Remember the location to which you save the file. https://raw.githubusercontent.com/toggledbits/Sonos-Vera/stable/L_SonosTTS.lua
  2. Open the uploader at Apps > Develop apps > Luup files
  3. Drag the file to the “Upload” button. The file will be uploaded and Luup will reload.
This should do it.
Thanks a lot. Yes, I’m with Vera 3 so old firmware. Downloaded the file, uploaded it and reloaded Luup engine. However the error is still similar (a bit different logs but the error is the same):
50 05/22/20 16:59:08.323 luup_log:535: Sonos: (tts debug) AzureTTSEngine:say() LuaSec “0.4”, using protocol “tlsv1_2” for request <0x2b582310>
02 05/22/20 16:59:08.379 luup_log:535: Sonos: AzureTTSEngine:say() conversion request failed, invalid protocol <0x2b582310>
02 05/22/20 16:59:08.380 luup_log:535: Sonos: (tts) engine Azure Speech Service error: request failed invalid protocol <0x2b582310>
02 05/22/20 16:59:08.382 luup_log:535: Sonos: (tts) Engine “Azure Speech Service” produced no audio <0x2b582310>
OK. Sit right. I forgot my own CHANGELOG advisory: no Azure for 3/Lite due to encryption limitations. But there’s a possible workaround. Let me see if I can work it out.
I tried pretty much every other option and couldn’t make them work. I don’t have where to install MaryTTS … so Azure was the only option left to try. I guess I’ll have to upgrade my Vera at last. I just wanted another Vera with at least 4 LAN ports but I think there won’t be any such no more.
OK. I think I got it done. Pull the same file and install using the same instructions previously given.
After Luup finishes reloading, go into the master device’s Settings tab, and you’ll find a new setting in the TTS section called “Requestor”. Change that to curl. Save the settings, and then reload Luup again (whatever your favorite way). Then try TTS again.
It really did it. Works like a charm. Thanks a lot.
