Hoping to get some help as I’m lost here. The built in Vera alerts are really messed up for me for some reason, for example if I say when a light goes on, send me a notification, it definitely does, but it sends it like 10 times followed by “You’ve exceeded your quota for the day.” So I was hoping VeraAlerts would be better in that regard and installed it. Bit disappointed to find out there’s a 30 day trial though as my plugin kept saying that with 2 free profiles, but even when I had fresh installed with no profiles, it would always say error, you don’t have a valid registration for this plugin so I just bought it.
Anyway, I’m just a bit confused as to how this all works as the website is a bit confusing. From what I understand, if I want a notification then I need to set it up from the actual device that I want to notify and not from this app? Hoping that’s not the case, as I don’t want something to always notify me, I want there to be criteria, such as if the house is in “Away” mode, and the front door opens, only then send me a notice, otherwise not. So not sure if this can do that?
The main issue though is that when I go to the notification configuration tab in the plugin, it’s always empty, unless I check the box “Process Notifications” which by default is unchecked. However it says checking that will process notifications in parallel to the built in ones. When I check the box, the notifications do work, but turning a light on sends 4 notices now, 2 from this plugin and then 2 from the built in notification system (using SMTP right now).
So 1) Does this plug in support criteria for the notifications, such as the one I mentioned above? Email me if motion is detected, door is open, that type of thing but only if it meets a criteria? I know I can select if it is armed, but that doesn’t work as I have a plug in that arms the house when I leave, then when I come home it gives me 30 seconds to disarm everything. If the Vera sends notifications based on something being armed, then it sends that alert before I can disarm the system, meaning I’d have to disarm it from the outside before opening the door.
- How do I use this plugin only without the built in Vera notifications as well, as they are really messed up?
Thanks!
