Having A Luup Code Screen/Window On HomeWave
Probably a long shot, :wink:
To allow me to move almost totally away from the web based Vera UI, do you have any plans to add the ability for users to create a Luup code test screen?
By that i mean - as I like to test and learn Luup, to save someone always having to go to Apps/Develop Apps/Test Luup Code (Lua), having the ability via HomeWave to havea button that brings up a Luup test window/page would be cool :wink:
Not sure if it is even possible, but thought I’d ask…
Hmm, not sure if it’s even possible to run arbitrary Luup over the Vera API.
I have my fingers crossed that you’ll come across a way to do it.
I pretty much use my iPad for everything now,so the ability to create and send Vera Luup Code field via HomeWave would be cool, Maybe consider my Idea to be for a ‘Developer’ panel that allows more advanced users to test code and maybe also view the logs.
But I appreciate that might not be easy to do and may take you away from the original intention of your apps design.
