I currently have 2 Harmony Hubs on my network, they both work through the app in the ui7 on my edge controller. The issue im having is that one of them keeps loosing the ip address configuration. I have the DHCP static reservation for both hubs but the controller always forgets the one in the living room. Always the same one never the other one. Anyone see this behavior or have a fix for it. I have newest firmware on everything.
I have 2 of these as well and never encountered this problem. Are you losing the ip address configuration on the vera app or is it dropping from your network?
If it is dropping from your network, you might want to look at either your wifi coverage and make sure you have no ip address conflicts.
Some have this problem with more plugins, others do not (I don’t on three units).
What some say might help is in the Net & Wi-Fi settings. Disable Automatic Device Detection. On “How does Vera connect to the Internet?” select “Manually configure (advanced)” and disable the LAN “DHCP server” (set to No).
