I’m still struggling with the plugin. I’ve uninstalled the plugin and removed all plugin files manually from openluup. Then I reinstalled the plugin, but now I don’t get the settings tab at the device page. I also tried to create the harmony device manually, but this had the same result.
I don’t know if this is a plugin issue or openluup, but maybe you can help me debug this issue.
See my log files attached:
One for the installation of the plugin and one for creating the harmony device manually
The only thing that stands out for me is the error:
openLuup.chdev:: [string “L_Harmony.lua”]:122: module ‘bit’ not found:
