Hello all, posted this just a bit earlier in AV section, thought this might be better spot, hope that’s okay for second post.
I’ve been using the Harmony plugin for quite some time now and have never had any issues. Today when I try to initiate anything Harmony related it doesn’t work. If I go to the Harmony Control Device the plugin created and click on either Activities or Devices I get the following error:
Error : Failed to get data from Hub.
I’ve spent the last several hours trying to figure this out including reading previous posts about this. I’ve verified the IP address and sign-in credentials are correct. I’ve restarted my Vera Edge several times, the hub several times, rebooted my router several times, even did the whole recover and reload deal on the Harmony hub and remote.
Everything else on my network is working fine, I even run the hue emulator on a Raspberry PI and all the controls work with all my Alexa devices.
I also have the hub extender and I have the 4 home control buttons on my Elite remote set for various Vera devices and that works fine. I just can’t go the other way, can’t get Vera to talk to the Harmony Hub at all!
What am I missing?? Thanks for any input!
Dave
