I’ve been using the Harmony plugin for quite some time now and have never had any issues. Today when I try to initiate anything Harmony related it doesn’t work. If I go to the Harmony Control Device the plugin created and click on either Activities or Devices I get the following error:
Error : Failed to get data from Hub.
I’ve spent the last several hours trying to figure this out including reading previous posts about this. I’ve verified the IP address and sign-in credentials are correct. I’ve restarted my Vera Edge several times, the hub several times, rebooted my router several times, even did the whole recover and reload deal on the Harmony hub and remote.
Everything else on my network is working fine, I even run the hue emulator on a Raspberry PI and all the controls work with all my Alexa devices.
I also have the hub extender and I have the 4 home control buttons on my Elite remote set for various Vera devices and that works fine. I just can’t go the other way, can’t get Vera to talk to the Harmony Hub at all!
For them to block out Vera and not provide unofficial plugin or API is really bad. Vera doesn’t connect and phone home or any place else unless you tell it to. I use my Vera in vacation mode to turn on and off the TV in the family room through the Harmony Hub at random times and now apparently I won’t be able to do that any longer unless I can roll back the firmware which leaves me with a device that can never be updated again.
Troubleshooting:
I have attempted, to Sync using mobile app and Windows MyHarmony app.
I have disabled XMPP and re-enabled using the mobile app
Verified I can ping hub with correct IP
Rebooted hub
Rebooted Vera3 UI5 / ALTUI
Still cannot connect, anyone else having this issue with the firmware update?
6.5.14. 417 Expectation Failed
The 417 (Expectation Failed) status code indicates that the
expectation given in the request’s Expect header field
(Section 5.1.1) could not be met by at least one of the inbound
servers.
I’m hoping Logitech did not lock this API down to the local subnet, I have my Vera3 in an isolated subnet due to the uPNP traffic and an old bug for Onkyo plug-in that I use to use.
