I am really frustrated trying to find a way to do one little task… I search “IR” and certain modules say they have “IR capabilities” and then don’t elaborate on what that means.
MY DESIRED TASK: Have a module or device that I can program to send an IR signal to a “room air conditioner” to toggle it on or toggle off and have the ability to schedule this “ON/OFF” signal to happen, on my schedule… I might desire 10 times a day to turn it on for 10 minues then off for 50… or what ever.
With the AC unit I am working with, a simple appliance module Will Not Work… due to the electronic control unit, if you merely cut the power, then reinstate said porwer, the unit goes into OFF Mode… which is completely… AAAGGGGHHHH!
I don’t mind spending hundreds of bucks to get this ability, but I refuse to buy expensive controllers and modules on the outside chance that it actually can be set up to learn and send IR commands I need.
On another note… I do have an attic exhaust fan that it would be nice to operate periodically as well… now THIS thing WILL work on a standard 120V appliance module.
Thank You Very Much in advance for any help you may offer.
