[quote=“guessed, post:1, topic:185648”]I tar-balled the files and copied them over to the ODroid C1 and it started up just fine. I do have to run it in non-debug mode, in order to keep the log verbosity down, but it seems to have reasonable performance so far (albeit that I lost TTS for the moment)
I may upgrade to using the MMC module, since I’m only using a 16GB MiniSD (Samsung EVO, UHS-1) at the moment and it’s finicky to boot with their current drivers.
I’ll leave it running for a day and see if it’s worthwhile cutting over wholesale, but for the moment I’m running it on both my Mac Mini and the C1, with both hitting on Vera at the same time. tsk, tsk…[/quote]
This has now been running successfully on the Odroid C1 for about a week now. I shutdown the version from the Mac Mini last Thursday in order to complete the cutover, prior to heading to Vegas (with @strangely)
In that time, I’ve had a few people ask me for comment on the specifics of what I’m running, and the early feedback on the stack… so here’s the details so far:
Hardware
[ul][li]Odroid C1 - Quad Core 1.5Ghz ARM 5 Processor, 1GB RAM, RTC, 1GbE, onBoard IR Receiver[/li]
[li]Options added - 16GB EVO (UHS-1) Samsung MicroSD, Battery for RTC, Case, [micro] Barrel power connector, 5V 2A Power supply[/li][/ul]
Software
[ul][li]Ubuntu Linux version 3.10.43 (root@xu-b1) (gcc version 4.9.2 (Ubuntu/Linaro 4.9.2-0ubuntu1~14.04) ) #1 SMP PREEMPT Mon Jan 5 07:39:54 BRST 2015[/li]
[li]Java version “1.8.0_06”[/li]
[li]openHAB 1.6.0, with MiOS Bridge Binding 1.7.0 & [tt]/etc/init.d[/tt] startup script[/li][/ul]
The good…
[ul][li]Startup is on-par with the Mac Mini, even when diagnostic logging is enabled in openHAB.[/li]
[li]Ongoing runtime is not [noticeably] slower than the Mac Mini[/li]
[li]Power usage on the dedicated controller is better than the “lift” I was causing on my Mac Mini by running it there[/li]
[li]It’s small, being about the size of a RPi (I’ll post a picture for comparison shortly)[/li]
[li]There’s active forum discussion on the Odroid C1 board, and patches are coming in regularly for the issues identified[/li][/ul]
The bad…
[ul][li]The specific model of MicroSD Card I used has problems on reboot, and requires a power cycle instead of a software reboot[/li]
[li]I’ve had Java 8 crash once, and never had Java 7 crash on the Mac Mini[/li]
[li]I patched last week to “disable” the UHS-1 (MicroSD speed) to improve the power-on first-boot, but it didn’t fix the problem with reboot[/li]
[li]I lost the [native] Mac-based TTS I was using, due to the platform shift, and the “generic” TTS options aren’t as nice sounding as Samantha[/li]
[li]The barrel-jack power connector is tiny (2.8mm external, 0.7mm internal), and wasn’t able to be sourced locally[/li]
[li]There’s a problem with the Console Serial interface, which results in one Core going to 100% - work-around available, but no fix yet[/li][/ul]
Overall, it has a ways to go before it’s ready for wide-consumption, but it’s looking promising especially for the price-point.
