Hi All,
i am having this problem from last 2-3 weeks. VeraEdge stop responding and only way to fix is by hard rebooting.
logs shows it stuck in some infinite loop. log file is attached. if i tries to do ssh i get “segment fault” error message and then ssh disconnect.
Any idea what going on. do i have defective box
02 04/30/15 14:42:11.530 e[33;1mfinished check for exceptionse[0m <0x73a87520>
02 04/30/15 14:42:11.568 e[33;1mfinished check for exceptionse[0m <0x73a87520>
02 04/30/15 14:42:11.569 e[33;1mfinished check for exceptionse[0m <0x73a87520>
02 04/30/15 14:42:11.570 e[33;1mfinished check for exceptionse[0m <0x73a87520>
02 04/30/15 14:42:11.600 e[33;1mfinished check for exceptionse[0m <0x73a87520>
02 04/30/15 14:42:11.661 e[33;1mfinished check for exceptionse[0m <0x73a87520>
02 04/30/15 14:42:11.662 e[33;1mfinished check for exceptionse[0m <0x73a87520>
02 04/30/15 14:42:11.663 e[33;1mfinished check for exceptionse[0m <0x73a87520>
02 04/30/15 14:42:11.663 e[33;1mOL: (0xaba794) (>62861) ThreadedClass …/JobHandler/JobHandler.cpp l:431 time: 6:00:00p (1430422931 s) thread: 0x77ca4000 Rel: Y Got: Ye[0m <0x73a87520>
02 04/30/15 14:42:11.664 e[33;1mfinished check for exceptionse[0m <0x73a87520>
02 04/30/15 14:42:11.664 e[33;1mOL: (0xea429c) (>63294) ThreadedClass …/JobHandler/JobHandler.cpp l:431 time: 2:42:04p (7 s) thread: 0x774e4520 Rel: Y Got: Ye[0m <0x73a87520>
02 04/30/15 14:42:11.665 e[33;1mOL: (0xea429c) (>63397) ThreadedClass ThreadedClass.cpp l:49 time: 2:42:10p (1 s) thread: 0x74287520 Rel: Y Got: Ye[0m <0x73a87520>
02 04/30/15 14:42:11.665 e[33;1mfinished check for exceptionse[0m <0x73a87520>
02 04/30/15 14:42:11.666 e[33;1mOL: (0xeb28bc) (>63399) SendMutex …/ZWave/ZWaveSerial.cpp l:496 time: 2:42:10p (1 s) thread: 0x774e4520 Rel: N Got: Ye[0m <0x73a87520>
02 04/30/15 14:42:11.666 e[33;1mfinished check for exceptionse[0m <0x73a87520>
02 04/30/15 14:42:11.666 e[33;1mOL: (0xeb2900) (>63400) SendReceiveMutex …/ZWave/ZWaveSerial.cpp l:497 time: 6:00:00p (1430422931 s) thread: 0x774e4520 Rel: Y Got: Ye[0m <0x73a87520>
---------------exited-------------
---------------after sleep-------------
---------------after kill -9-------------
any help…
just happened again
02 05/04/15 12:02:16.944 e[33;1mfinished check for exceptionse[0m <0x7363b520>
02 05/04/15 12:02:16.945 e[33;1mfinished check for exceptionse[0m <0x7363b520>
02 05/04/15 12:02:16.946 e[33;1mfinished check for exceptionse[0m <0x7363b520>
02 05/04/15 12:02:16.977 e[33;1mfinished check for exceptionse[0m <0x7363b520>
02 05/04/15 12:02:16.978 e[33;1mfinished check for exceptionse[0m <0x7363b520>
02 05/04/15 12:02:16.979 e[33;1mfinished check for exceptionse[0m <0x7363b520>
02 05/04/15 12:02:16.980 e[33;1mfinished check for exceptionse[0m <0x7363b520>
02 05/04/15 12:02:16.981 e[33;1mfinished check for exceptionse[0m <0x7363b520>
02 05/04/15 12:02:16.981 e[33;1mOL: (0x986f3c) (>272650) alarm AlarmManager.cpp l:109 time: 12:02:14p (2 s) thread: 0x73e3b520 Rel: Y Got: Ye[0m <0x7363b520>
02 05/04/15 12:02:16.982 e[33;1mOL: (0xd6e03c) (>272662) ThreadedClass …/JobHandler/JobHandler.cpp l:431 time: 12:02:14p (2 s) thread: 0x77098520 Rel: Y Got: Ye[0m <0x7363b520>
02 05/04/15 12:02:16.983 e[33;1mfinished check for exceptionse[0m <0x7363b520>
02 05/04/15 12:02:16.983 e[33;1mOL: (0xd6e03c) (>272749) ThreadedClass ThreadedClass.cpp l:49 time: 12:02:15p (1 s) thread: 0x77858000 Rel: Y Got: Ye[0m <0x7363b520>
02 05/04/15 12:02:16.984 e[33;1mfinished check for exceptionse[0m <0x7363b520>
02 05/04/15 12:02:16.984 e[33;1mOL: (0xd6c0b4) (>272753) SendMutex …/ZWave/ZWaveSerial.cpp l:496 time: 12:02:15p (1 s) thread: 0x77098520 Rel: N Got: Ye[0m <0x7363b520>
02 05/04/15 12:02:16.985 e[33;1mfinished check for exceptionse[0m <0x7363b520>
02 05/04/15 12:02:16.985 e[33;1mOL: (0xd6c0f8) (>272754) SendReceiveMutex …/ZWave/ZWaveSerial.cpp l:497 time: 6:00:00p (1430758936 s) thread: 0x77098520 Rel: Y Got: Ye[0m <0x7363b520>
Or you have totally exhausted memory so even SSH will not run.
What is the Exit Code ?
Some are normal restart like Code 250.
BTW, kill -9 is linux command to kill process
i think memory wise everything is fine, i have 64K swap file enable on USB drivre too
root@MiOS_xxxxx:~# cat /proc/meminfo
MemTotal: 126720 kB
MemFree: 19828 kB
Buffers: 32904 kB
Cached: 26148 kB
SwapCached: 68 kB
Active: 45072 kB
Inactive: 40968 kB
Active(anon): 13036 kB
Inactive(anon): 14768 kB
Active(file): 32036 kB
Inactive(file): 26200 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 65532 kB
SwapFree: 65464 kB
Dirty: 52 kB
Writeback: 0 kB
AnonPages: 26940 kB
Mapped: 6264 kB
Shmem: 816 kB
Slab: 11340 kB
SReclaimable: 4168 kB
SUnreclaim: 7172 kB
KernelStack: 664 kB
PageTables: 456 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 128892 kB
Committed_AS: 95788 kB
VmallocTotal: 1048372 kB
VmallocUsed: 2232 kB
VmallocChunk: 1036376 kB
root@MiOS_xxxxxx:~# cat /proc/swaps
Filename Type Size Used Priority
/data/log/swap/swapfile file 65532 68 -1
