just received my Vera light and try to connect to it.
It works but as vera can’t acces Internet, I try change network setting … and I think I got a problem.
Now I can’t connect to it directly or with vera web server.
I also try to connect a PC to it : nothing.
Is it possible to hard reset to factory ?
I don’t find how to do it (there is no reset button)
regards
David
I unplug all and plug the vera again on my DHCP Router :
- Power on steady (blue led)
- Ready on steady (Orange led)
- Network blinking (Green led)
- Scan network => All IP address are know. so no vera. (during my first try, 192.168.0.186 have been assign to vera)
David
Have not had to do a hard reset of the Vera Lite yet, but I believe the reset button is the hole next to the green minus button. You will need something to put in there and do a quick double tap of the button. Before doing this, try and connect the vera unit directly to your computer using the ethernet cable. Change the ip address to 192.168.81.2 and try accessing the vera unit with 192.168.81.1.
Save my life
I try to do it but … find that I put 198.188.81.2 previously
So I can connect and change the value I put in network (192.168.0. ) <= Without the last digit !
Thanks a lot
