Earlier today, I had a HA18C stop responding to the switch.
It’s wired in 3-way mode.
From either Vera or from the remote (non Z-Wave) switch I could still control the HA18 switch and thus turn on/off the (incandescent) lamps that the switch was hooked to.
However, the local switch just did not respond.
I killed the power at the breaker for 10s and then powered back up. The local switch on the HA18 started working again.
Has anyone else experience this? I’m about to a lot more of these switches, but if it quirks like this occasionally, that will be quite problematic.
Intermatic has (well, perhaps had) excellent support. I had two modules failed - they replaced both with no receipt or other proof of purchase; it took just few days to get replacement.
