Group Association and Dimmer FGD211
I have a switch with two buttons that are connected to the output S1 and S2 of a dimmer.
The button lights up a lamp behind the switch.
I try to combien the second button to turn it over in another lamp.
But this does not work.
Have you any idea what’s wrong ?
As I’ve said in the other thread, your wiring is wrong. You need to put the dotted red lines into the Sx, not Live
I’ve done that, the dotted red lines is connected into the Sw.
But the problem is the same…
Maybe is it because I use a bi-stable button ?
Of course if I create association to Group1 it works but the second button do exactly the same.
What I don’t arrive to do is to create different associations, one for Group1 and the other to Group2.
If you use a monostable (retractive / momentary) switch, you need to set parameter 14 to 0 (default). If you use a bi-stable (rocker) switch, you need to set parameter 14 to 1.
If you want switch 1 and switch 2 both to operate the same light, you need to set parameter 17 to 1.
[quote=“Quinten, post:4, topic:170919”]If you use a monostable (retractive / momentary) switch, you need to set parameter 14 to 0 (default). If you use a bi-stable (rocker) switch, you need to set parameter 14 to 1.
If you want switch 1 and switch 2 both to operate the same light, you need to set parameter 17 to 1.[/quote]
I use a bi-stable button => parameter 14 is set to 1
I want that the dimmer #10 associate the lamps 1 and 2 when I push the switch S2.
Ah ok, that picture makes sense now. I haven’t used the association function on the fibaro, sorry :frowning:
I’ve changed the dimmer and I made the same configuration by adding in device options a group 2.
Now it is working well.
The problem was only to reset the configuration of the dimmer.
