Have a question/suggestion - my vera doesn’t change very often, and 95% of the time I’m just using it at home. Rather than have it go to the vera (or fwd.mios.com) to poll all the devices, can there be an option to cache the info? I think this would make it much faster.
Any problems you could see with that? I think Home Buddy (the Android Vera client) does this, and it seems to work pretty well.
actually the program caches the data for all the units configured. When the program loads it will use this data first. Then in the background it will update the data to the current state. I just recently released v1.4 which has some other new features, check out the link below Once microsoft releases more api’s later this month, i have a bunch of new features i’ll be implementing.
