It works for me in localhost but not in remote access.
I have made an update of the parameters of Grasshopper after updating to UI7, but it wasn’t working in remote access.
So, I uninstall Grasshopper and reinstall it.
Like before, it works, in local (WiFi) but not in remote access (when I am outside home).
I have tried several hosts that I have find in the forum, but always the same .
Nb : when I was on UI5, it was working both in wifi (local address) and outside home (remote).
UI7 works just like UI6, however i’ve seen issues with their servers being flaky. When you setup your unit you should see two hosts created. One is for remote and your local ip. If your not getting both that means the authentication servers are not behaving properly. Their auth system is much more complicated now so its pretty much impossible to just assign a host manually even though i have a UI for it. You have to authentication on multiple servers (some of which you don’t even know about that happen under the covers). If you continue to have issue i always suggest to people to create a read only account that i can access to see what is happening. Just email me and we can take a look.
