Enhancing the vera server checks to now happen before every vera command while also adding logic to refresh the units server info if none of the servers report they are alive based on the current connectivity. Since the remote servers seem to rotate a lot it should reduce the number of times you might get an error about connectivity. This also should help reduce the need to retry a command assuming you have valid connectivity at the time and your vera is running properly.
