- updates to hide location functionality if background tasks are disabled. Add more text regarding this on the appropriate pages.
- Fixed json serialization issue on logging which would cause error popups frequently for some users
- Fix for camera refresh on load
- Added network info to the logging info for all http requests
- Fix for network connectivity check that would make the app think there was no network connection if you happen to be using the vpn functionality
- Enhancements for camera image loaded to properly detect if vera is responding with a non-image response typically related to an authentication issue
- Added a more proper error message and handling for authentication issues regarding UI5 or earlier
