- Support for UI6 and the MMS authentication system. You will now see authentication options when setting up your units. If for some reason the session expires before the normal 24 hour cycle you can refresh the session with the “Refresh Session” button in Settings
- Enhancements to voice commands to allow for exclusion of the unit name. If not included, it will default to the last selected unit or the first unit in the list. Ex. run heat the house, change power switch to on on lamp, go to thermostat
- Reactivated background processes. You should see the option in settings.
The local data upgrade should happen seamlessly but if an issue arises just use the Reset All option in settings. Enjoy!
