I’ve basically given up on using dataMine to graph room temperature over time.
Can EventWatcher be used in this manner?
EventWatcher can only graph what’s in the memory buffer… typically one or two days worth of data, which gets lost between reloads.
DataYours is really what you need for long term archive and plotting. There is a new release which is currently in testing and which will be much easier to install, so perhaps hold fire for a little while., unless you’re very keen to try.
@akbooer, will this new easy release also work on ui5? Or will it only be for ui7?
Even the current release works on UI5 and UI7.
It is, I admit, confusingly badged as DataYours for UI7
