Anyone with a GR-105 or EBV-105 (ball valve control) ever have an issue where the device dropped off your network? Mine was fine for 6 months and then just dropped off. I removed the device from Vera and tried to add it back by clicking the power button quickly 3 times but no dice (I tired about 20 times - different length presses). I tried to exclude it but no luck there either. The LED is completely off - not flashing or on. I would think the device died/power issue, except if I manually move it to the on/open position, the valve kicks in and closes the valve since that was the last state it was in before it dropped off the network. I tried holding the power button for 10 seconds to reset it but no dice.
Hoping maybe there is someone else that knows the way out of the woods…
