hellovn
November 23, 2014, 2:20pm
1
Hi All,
I have been able to play a music to my windows 8.1 media player and BubbleUPNP for android through vera dlna plugin. However, when trying to play Google TTS, my windows media player shows a popup to enter my vera username/password while my BubbleUPNP does not say anything. Here is my vera logs:
] <0x2f18c680>
50 11/23/14 9:41:49.755 luup_log:83: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[100:00:00http://192.168.0.3:80/Say.83.mp3dc:title Google TTS</dc:title>http://192.168.0.3:80/Say.83.mp3 upnp:class object.item.audioItem.musicTrack</upnp:class>NOT_IMPLEMENTEDNOT_IMPLEMENTEDNETWORKNOT_IMPLEMENTEDNOT_IMPLEMENTED] LEAK this:8192 start:1818624 to 0x1816000 <0x2ef8c680>
50 11/23/14 9:41:49.760 luup_log:83: DLNA: debug: service.__index: Accessing non-existing function GetPositionInfo <0x2ef8c680>
50 11/23/14 9:41:49.760 luup_log:83: DLNA: debug: GetPositionInfo(‘http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ’, ‘urn:schemas-upnp-org:service:AVTransport:1’) Called with parameter count=1 <0x2ef8c680>
50 11/23/14 9:41:49.761 luup_log:83: DLNA: debug: UPnP_request: url=[http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ], body=[
0
] <0x2ef8c680>
50 11/23/14 9:41:49.788 luup_log:84: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[Play] LEAK this:8192 start:1826816 to 0x1818000 <0x2f18c680>
50 11/23/14 9:41:49.789 luup_log:84: DLNA: debug: service.__index: Accessing non-existing function GetMediaInfo <0x2f18c680>
50 11/23/14 9:41:49.790 luup_log:84: DLNA: debug: GetMediaInfo(‘http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ’, ‘urn:schemas-upnp-org:service:AVTransport:1’) Called with parameter count=1 <0x2f18c680>
50 11/23/14 9:41:49.790 luup_log:84: DLNA: debug: UPnP_request: url=[http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ], body=[
Please advise and thanks a lot.
Please check this topic, even if it is relative to Sonos: http://forum.micasaverde.com/index.php/topic,25689.0.html
You probably secured the local access to your Vera ?
hellovn
November 24, 2014, 12:44pm
3
Hi Lolodomo,
I have unchecked “secure my vera” and rebooted it.
My vera and my android are in the same subnet.
I could play an mp3, volume up/down but not TTS.
My device RouterIp set to empty and RouterPort set to 80
I am using ui7 & veralite (fireware 1.7.439)
DLNA plugin version 1.2
It still does not work for me
Thanks.
Unfortunately, your logs are weird and I don’t have the initial TTS request. The first line of your logs could be the result of the request and looks good (200), even if I see “NOT-IMPLEMENTED” strings at the end. Is it a bad copy/paste of logs ?
Is it logs when using WMP ?
What about logs with BubbleUPnP. I know that it works with BubbleUPnP and I can check. I cannot check with Windows 8.1 (only Windows 7).
Why the media player would request a Vera username/password if you have not secured your Vera local access ?
hellovn
November 24, 2014, 5:45pm
5
Here is my log for BubbleUpNP
08 11/24/14 13:38:37.346 JobHandler_LuaUPnP::HandleActionRequest device: 84 service: urn:dlna-org:serviceId:DLNAMediaController1 action: NotifyAVTransportChange <0x30b75680>
08 11/24/14 13:38:37.346 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=84 <0x30b75680>
08 11/24/14 13:38:37.346 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:dlna-org:serviceId:DLNAMediaController1 <0x30b75680>
08 11/24/14 13:38:37.346 JobHandler_LuaUPnP::HandleActionRequest argument action=NotifyAVTransportChange <0x30b75680>
08 11/24/14 13:38:37.346 JobHandler_LuaUPnP::HandleActionRequest argument LastChange= <0x30b75680>
08 11/24/14 13:38:37.347 JobHandler_LuaUPnP::HandleActionRequest argument sid=uuid:7f243583-448f-4eaf-b7a5-bbcc6fcf0d11 <0x30b75680>
50 11/24/14 13:38:37.381 luup_log:83: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[100:00:00dc:title Google TTS</dc:title>http://192.168.0.3:80/Say.83.mp3 upnp:class object.item.audioItem.musicTrack</upnp:class>http://192.168.0.3:80/Say.83.mp300:00:0000:00:0021474836472147483647 ] <0x2ae00000>
04 11/24/14 13:38:37.384 <0x2ae00000>
50 11/24/14 13:38:37.385 luup_log:84: DLNA: debug: handleAVTransportChange for device 84 value <0x2ae00000>
50 11/24/14 13:38:37.388 luup_log:84: DLNA: debug: GetPositionInfo(‘http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ’, ‘urn:schemas-upnp-org:service:AVTransport:1’) Called with parameter count=1 <0x2ae00000>
50 11/24/14 13:38:37.389 luup_log:84: DLNA: debug: UPnP_request: url=[http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ], body=[
0
] <0x2ae00000>
50 11/24/14 13:38:37.429 luup_log:84: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[100:00:00dc:title Google TTS</dc:title>http://192.168.0.3:80/Say.83.mp3 upnp:class object.item.audioItem.musicTrack</upnp:class>http://192.168.0.3:80/Say.83.mp300:00:0000:00:0021474836472147483647 ] <0x2ae00000>
04 11/24/14 13:38:37.432 <0x2ae00000>
50 11/24/14 13:38:38.100 luup_log:83: DLNA: debug: TTS endPlayback for device 83 <0x2ef34680>
50 11/24/14 13:38:38.140 luup_log:83: DLNA: debug: restorePlaybackContext: start <0x2ef34680>
50 11/24/14 13:38:38.141 luup_log:83: DLNA: debug: Stop(‘http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ’, ‘urn:schemas-upnp-org:service:AVTransport:1’) Called with parameter count=1 <0x2ef34680>
50 11/24/14 13:38:38.142 luup_log:83: DLNA: debug: UPnP_request: url=[http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ], body=[
0
] <0x2ef34680>
50 11/24/14 13:38:38.178 luup_log:83: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[] <0x2ef34680>
50 11/24/14 13:38:38.180 luup_log:83: DLNA: debug: SetMute(‘http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/RenderingControl/action ’, ‘urn:schemas-upnp-org:service:RenderingControl:1’) Called with parameter count=1 <0x2ef34680>
50 11/24/14 13:38:38.181 luup_log:83: DLNA: debug: UPnP_request: url=[http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/RenderingControl/action ], body=[
0Master0
] <0x2ef34680>
50 11/24/14 13:38:38.240 luup_log:83: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[] <0x2ef34680>
50 11/24/14 13:38:38.241 luup_log:83: DLNA: debug: SetVolume(‘http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/RenderingControl/action ’, ‘urn:schemas-upnp-org:service:RenderingControl:1’) Called with parameter count=1 <0x2ef34680>
50 11/24/14 13:38:38.242 luup_log:83: DLNA: debug: UPnP_request: url=[http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/RenderingControl/action ], body=[
0Master15
] <0x2ef34680>
50 11/24/14 13:38:38.329 luup_log:83: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[] <0x2ef34680>
50 11/24/14 13:38:38.331 luup_log:83: DLNA: debug: SetAVTransportURI(‘http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ’, ‘urn:schemas-upnp-org:service:AVTransport:1’) Called with parameter count=1 <0x2ef34680>
50 11/24/14 13:38:38.332 luup_log:83: DLNA: debug: UPnP_request: url=[http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ], body=[
0http://192.168.0.15/1.mp3
] <0x2ef34680>
50 11/24/14 13:38:38.443 luup_log:83: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[] <0x2ef34680>
50 11/24/14 13:38:38.445 luup_log:83: DLNA: debug: SetPlayMode(‘http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ’, ‘urn:schemas-upnp-org:service:AVTransport:1’) Called with parameter count=1 <0x2ef34680>
50 11/24/14 13:38:38.445 luup_log:83: DLNA: debug: UPnP_request: url=[http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ], body=[
0NORMAL
] <0x2ef34680>
50 11/24/14 13:38:38.581 luup_log:83: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[] <0x2ef34680>
50 11/24/14 13:38:38.582 luup_log:83: DLNA: debug: Stop(‘http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ’, ‘urn:schemas-upnp-org:service:AVTransport:1’) Called with parameter count=1 <0x2ef34680>
50 11/24/14 13:38:38.583 luup_log:83: DLNA: debug: UPnP_request: url=[http://192.168.0.26:58645/dev/5f0d28a1-5971-84d8-ffff-ffffa4cf3814/svc/upnp-org/AVTransport/action ], body=[
hellovn
November 24, 2014, 5:50pm
6
Although I have unsecured my vera. When trying to access vera through a local IP (192.168.0.x), firefox still shows me a popup login:
“A username and password are being requested by http://192.168.0.3 . The site says: “HomeControl””
If I secure my vera, I could not access the local IP from the network and I have to go through home.getvera.com .
[quote=“hellovn, post:6, topic:184303”]Although I have unsecured my vera. When trying to access vera through a local IP (192.168.0.x), firefox still shows me a popup login:
If I secure my vera, I could not access the local IP from the network and I have to go through home.getvera.com .[/quote]
That is probably the reason why TTS is not working. You must have access to the Vera WEB server without having to enter a password. Entering your Vera IP should open your Vera UI.
hellovn
November 24, 2014, 11:50pm
8
I think it may be a bug in ui7 firmware 1.7.439. I wonder if anyone succeeds TTS with ui7.
It was working with 1.7.388.
hellovn
November 25, 2014, 11:48pm
10
Hi Lolodomo,
How about 1.7.439? I have sent an email to vera support but have not heard anything back from them. If this is the case, could we integrate the username/password into DLNA plugin?
THanks,
Take a look in the forum, other users had the same issue than you with local access to UI and finally solved this issue.
hellovn
November 26, 2014, 2:14am
12
For my windows media player, it seems my text to speech is working after I entered my username/password to the login box. My test string was too short before and that’s why i didn’t hear anything. I am still trying to figure out why my vera still shows a message “The server is asking for your username/password”…I know for sure that my vera “secure my vera” is unchecked and rebooted as I could access my vera using local IP and enter a username/password.
hellovn
November 30, 2014, 12:07am
13
Finally, A tech support from Vera Control remotely logged into my vera and fixed the problem. I could play TTS without the login popup now. Thanks Lolodomo for your help. However, after giving up with DLNA as I thought Vera may never reply my support email, I have bought an airport extreme and a few airport expresses and integrate them with my iMac via Airplay. Both are working great. The benefit of using DLNA is I don’t have to keep my iMac on all the time
