Clems
May 17, 2020, 7:49am
1
Hello !
I juste set-up GH today, everything works very well.
Except scenes, I’m not able to see any scene on GH.
Unfortunuately, that topic is not up to date https://support.getvera.com/hc/en-us/articles/360036497073-Google-Home-Guide-Running-Vera-Scenes
All my devices and apps are on the latast SW version, and scenes are activated in the device display list on Login
Could you say me how to display the scene in GH ?
Thank you!
cw-kid
May 17, 2020, 12:56pm
2
Assume you have asked a Google Home speaker to “update devices” ?
Clems
May 17, 2020, 2:56pm
3
I am using GH on phone.
I can see the scenes through Google Assistant, but not through GH.
You mean in the Home app you cannot see the Vera scenes ? But you can see the Vera devices?
They have changed the layouts of the Home app recently.
Open the Home app, in the top right hand corner click your account, then select “Assistant Settings” from the list, then select the “Assistant” tab, then select “Home Control” from the list.
Look in the “Vera Smarter Home Control” section, your Vera scenes along with the Vera devices should be listed there?
So does that answer your question ?
If you want to run a Vera scene you cannot just click on a Vera scene from the Home app / Google Assistant app.
You have to issue a voice command to Assistant / Google Home speaker:
You say:
run “scene-name”
Or in Assistant on your phone, you can hit the keyboard icon and then you can type in the command to run the scene e.g.
You type in:
run “scene-name”
Clems
May 17, 2020, 3:27pm
8
ok thank you, now I it is quite clear about how tu run scene!
You can also use Routines in the Home app.
You can create a routine with various different say phrases to run a particular Vera scene.
For example say I have a Vera scene named “Open Curtains”
When I say:
Open the curtains
Open curtains
Curtains open
Open my curtains
Assistant Will:
run open curtains
So I can say all those different phrases to run the one Vera scene.
Or you can now click on that routine in the Home app to run your Vera scene.
