i know there are other posts about connecting google home to Vera controllers, but has a workable system been found since googles use of the Phillips Hue Api changed an rendered the HA-Bridge impossible to pair with? if i cant find a work around then im going to be looking to ditch my vera for a more up to date system ![]()
Here try this http://forum.micasaverde.com/index.php?board=89.0
i have tried it, installed on a raspberry pi however was never able to actually turn lights on or off. when i gave it a command, it just asked “which switch” constantly.
Did you check out:
http://forum.micasaverde.com/index.php/topic,48913.0.html
