I would like to use Google Chart Tools on one of the device tabs. It is possible to use java script on tabs so I guess it should work in general. Google Chart tools require to load an AJAX API before you can use it and I wonder how to do that. Basically, I wonder where the line “” should go. Did anyone try this before (With or without success)?
I can log sensor data in a text file on the system and I can download it then and make nice graphs. However, I would like to see some sensor data charts directly in the dashboard and thought I could use Google Charts to read and present whats in the text files.
I considered it for the CurrentCost EnviR plugin, but decided to go with the simpler Image Chart API, mostly for the reason you mention.
While searching, I did see some suggestions that you could use DOM manipulation to insert (local-to-Vera copies of) the Google Chart JavaScript files into the current document’s when your tab’s JavaScript loads. It all seemed a bit precarious.
Yes that is a good hint; that is the sort of thing I am looking at. (I am not familiar with UIs; things I normally deal with do not have user interfaces)
