Keep in mind the Universal Devices ISY994i ZW. I switched over to one after my Vera3 would periodically just lock up and leave me high and dry (along with lack of remotely modern programing ability, etc). The ISY is an absolute ROCK! It never stops, never crashes and never dies. The programming language is robust and you can basically do anything you can dream up. And it’ll just work.
ISY got its start with Insteon and the default unit still does Insteon, but you can buy a unit with No insteon support if you never plan to use it. ZWave support is great. It may not support every single ZWave device out there, but so far has supported everything I’ve thrown at it (light switches, thermostats from multiple manufactures, door locks, temp/climate sensors, door sensors, motion sensors, power/energy sensors, etc).
The company has a well supported user forum with regular and active participation by the company. Firmware updates are not crazy frequent, but generally add new features and almost never seem to introduce any problems – things just get better each release.
If you’re just getting going with your HA project, the ability to knit Insteon lighting devices in (cheaper and more powerful than most ZWave light switches) is great, but again, if you have no interest in Insteon, you can just ignore it. No “cloud” subscription requirements either (though available, should you want it).
I’ve been doing HA for 20+ years and from a reliability and programability standpoint, the Vera was a huge step back into unreliable automation (aka toy automation). I tried – really bashed my head – for the better part of a year before giving up. I wanted it to work and I tried everything and anything to get it reliable.
Since going to the ISY, we forget the automation is even there (which is how it should be – “silent, ordinary magic”).
Also, ISY just finished their Amazon Echo integration and once setup, it’s easy to use and actually has wound up being useful to the household.
Gerry
