GoControl GD00Z stopped open/closing
I’ve had two GD00Z on my garage doors for years - one a Linear, and one a GoControl, both have been working fine. I don’t often use them to open/close but I get alerts on those events so I know at least the senors are working.
A couple weeks ago I tried to use the Vera phone app to close the door that was using the GoControl, and I heard the familiar beep-beep-beep that precedes the Vera closing the door, but then nothing happened. This happened repeatedly and no longer will open or close the door. As I said, the sensor works fine and it’s clear that the unit receives the message since it beeps. I cycled the power to no effect, but I haven’t tried to unpair/re-pair the unit.
The other unit (Linear) continues to work fine.
I’m not sure if upgrading to 1.7.919 caused the issue as I did that a few weeks back as well.
Any help would be appreciated.
It’s possible the wires just came loose from the motor; vibration can do that. Try removing them, checking for any breaks in the wires, and reconnecting to the motor.
I think if you put a multimeter on the wires in continuity mode, you should see the circuit close when the unit activates.
I just so happen to have the same setup for my two garage doors and have never seen this problem. You likely have some defective hardware there. Some lose cable or some issues with your garage door are likely.
GoControl is a branded Linear which is part of Nortek. Seems like a lot are failing. I called their customer service and got an RMA #. Sent it in yesterday. People over at SmartThings are getting new ones within a week.
see post there Linear Garage Door Opener Stopped Working - #18 by jshessen - Connected Things - SmartThings Community
I just called 855-546-3351 and they told me to send receipt to returns@nortek.com. Within an hour they gave me an RMA. Looks like I will have to cover shipping back to them cost. Will update here.
Thanks for tips all. I did check the connection and it seemed solid, but I will try to reconnect just to be sure.
Received my new one this week. Installing today. RMA took 2 mins, $10 UPSP, 1 week turn around.
Looks like I’ll be doing the same. Thanks all.
My unit had quit working. I sent it to Linear and after a couple of weeks finally received a replacement unit today. It paired just fine and I get command sent ok but the unit never starts beeping or flashing its light or opening or closing the door. It displays nothing. I have unpaired and repaired the unit several times and still it does nothing. The command sent message is OK. Any ideas? I hope they didn’t send me a defective unit.
