[quote=“futzle, post:11, topic:184446”][quote=“kitts, post:10, topic:184446”]50 09/18/15 1:56:07.734 luup_log:138: Searching for UPnP devices… <0x2be30680>
50 09/18/15 1:56:07.735 luup_log:138: M-SEARCH sent to 239.255.255.250:1900 <0x2be30680>[/quote]
You truncated the log just as it was getting interesting. What happens after the last line you quoted?
Also: after you “Add Static”, you have to “Save” your changes. In UI5 this was obvious: click the big red SAVE button. In UI7 you still have to Save, but this involves backing out of the config page and running to Apps > Develop Apps > Serial Port Configuration > Reload Luup. There’s an element of timing and an element of luck in this. I’ve heard reports that doing it too fast, or too slow, will stop it working.
Another edit: Even though this is an unsupported plugin, it’s probably worth everyone writing to MCV with a support request. The sheer volume of people wanting their WeMo switches to work in their Veras might prompt them to take a look at the plugin, and make whatever small change it needs to work on UI7. They’ve got access to the source code just as anyone else does.[/quote]
Thanks for responding to this issue, I understand you have stopped supporting the plugin. I agree, Vera should pick this up and fix whatever that it need to get this working.
I have a Support email thread going on with Vera.
The Save part is where I am stuck with. I Reload Lupp engine so many times after adding Static.
I looked at the lupp code (programmer myself, cant figure out when the number of child device variable gets updates or saved)
Okay here is the full log: (10.0.0.211 and 10.0.0.212 are Belkin Switches)
50 09/18/15 20:56:27.963 luup_log:138: Starting WeMo plugin (device 138) <0x2b2e6680>
50 09/18/15 20:56:27.964 luup_log:138: Creating up to 0 children <0x2b2e6680>
50 09/18/15 20:56:27.965 luup_log:138: Roll call of child devices <0x2b2e6680>
50 09/18/15 20:56:27.966 luup_log:138: Searching for UPnP devices… <0x2b2e6680>
50 09/18/15 20:56:27.967 luup_log:138: M-SEARCH sent to 239.255.255.250:1900 <0x2b2e6680>
50 09/18/15 20:56:27.976 luup_log:138: M-SEARCH response received from 10.0.0.1 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:27.977 luup_log:138: Missing header LOCATION <0x2b2e6680>
50 09/18/15 20:56:27.978 luup_log:138: M-SEARCH response received from 10.0.0.1 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:27.979 luup_log:138: Response identifies itself as 10.0.0.1:5000 from UUID uuid:dd6d2c0e-b953-a631-31b9-3993ce0902fc <0x2b2e6680>
50 09/18/15 20:56:27.979 luup_log:138: M-SEARCH response received from 10.0.0.1 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:27.981 luup_log:138: Response identifies itself as 10.0.0.1:8200 from UUID uuid:4d696e69-444c-164e-9d41-e4f4c60d1422 <0x2b2e6680>
50 09/18/15 20:56:27.985 luup_log:138: M-SEARCH response received from 10.0.0.210 UDP port 33280 <0x2b2e6680>
50 09/18/15 20:56:27.987 luup_log:138: Response identifies itself as 10.0.0.210:49451 from UUID uuid:4d494342-5342-5645-0000-000002164561 <0x2b2e6680>
50 09/18/15 20:56:28.303 luup_log:138: M-SEARCH response received from 10.0.0.5 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:28.304 luup_log:138: Response identifies itself as 10.0.0.5:80 from UUID uuid:2f402f80-da50-11e1-9b23-00178818e57f <0x2b2e6680>
50 09/18/15 20:56:28.354 luup_log:138: M-SEARCH response received from 10.0.0.5 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:28.355 luup_log:138: Bad USN format from http://10.0.0.5:80/description.xml: uuid:2f402f80-da50-11e1-9b23-00178818e57f <0x2b2e6680>
50 09/18/15 20:56:28.404 luup_log:138: M-SEARCH response received from 10.0.0.5 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:28.405 luup_log:138: Bad USN format from http://10.0.0.5:80/description.xml: uuid:2f402f80-da50-11e1-9b23-00178818e57f <0x2b2e6680>
50 09/18/15 20:56:28.520 luup_log:138: M-SEARCH response received from 10.0.0.17 UDP port 33361 <0x2b2e6680>
50 09/18/15 20:56:28.522 luup_log:138: Response identifies itself as 10.0.0.17:1400 from UUID uuid:RINCON_B8E9372AC46401400 <0x2b2e6680>
50 09/18/15 20:56:28.790 luup_log:138: M-SEARCH response received from 10.0.0.3 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:28.791 luup_log:138: Missing header LOCATION <0x2b2e6680>
50 09/18/15 20:56:29.354 luup_log:138: M-SEARCH response received from 10.0.0.5 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:29.355 luup_log:138: Response identifies itself as 10.0.0.5:80 from UUID uuid:2f402f80-da50-11e1-9b23-00178818e57f <0x2b2e6680>
50 09/18/15 20:56:29.404 luup_log:138: M-SEARCH response received from 10.0.0.5 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:29.405 luup_log:138: Bad USN format from http://10.0.0.5:80/description.xml: uuid:2f402f80-da50-11e1-9b23-00178818e57f <0x2b2e6680>
50 09/18/15 20:56:29.456 luup_log:138: M-SEARCH response received from 10.0.0.5 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:29.457 luup_log:138: Bad USN format from http://10.0.0.5:80/description.xml: uuid:2f402f80-da50-11e1-9b23-00178818e57f <0x2b2e6680>
50 09/18/15 20:56:29.474 luup_log:138: M-SEARCH response received from 10.0.0.220 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:29.475 luup_log:138: Missing header LOCATION <0x2b2e6680>
50 09/18/15 20:56:29.845 luup_log:138: M-SEARCH response received from 10.0.0.211 UDP port 3081 <0x2b2e6680>
50 09/18/15 20:56:29.846 luup_log:138: Response identifies itself as 10.0.0.211:49153 from UUID uuid:Lightswitch-1_0-221345K1300F9D <0x2b2e6680>
50 09/18/15 20:56:30.969 luup_log:138: M-SEARCH response received from 10.0.0.10 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:30.970 luup_log:138: Response identifies itself as 10.0.0.10:8060 from UUID uuid:01091048-6c00-1051-80f6-000d4bbf7e45 <0x2b2e6680>
50 09/18/15 20:56:31.155 luup_log:138: M-SEARCH response received from 10.0.0.212 UDP port 3079 <0x2b2e6680>
50 09/18/15 20:56:31.156 luup_log:138: Response identifies itself as 10.0.0.212:49153 from UUID uuid:Lightswitch-1_0-221345K1300996 <0x2b2e6680>
50 09/18/15 20:56:31.523 luup_log:138: M-SEARCH response received from 10.0.0.20 UDP port 1900 <0x2b2e6680>
50 09/18/15 20:56:31.524 luup_log:138: Response identifies itself as 10.0.0.20:8060 from UUID uuid:015de0c9-0001-1064-80d3-b83e59d55453 <0x2b2e6680>
50 09/18/15 20:56:36.526 luup_log:138: Searching complete <0x2b2e6680>
50 09/18/15 20:56:36.526 luup_log:138: UPnP location http://10.0.0.1:5000/Public_UPNP_gatedesc.xml <0x2b2e6680>
50 09/18/15 20:56:36.527 luup_log:138: UPnP udn uuid:dd6d2c0e-b953-a631-31b9-3993ce0902fc <0x2b2e6680>
50 09/18/15 20:56:36.528 luup_log:138: Unknown uuid uuid:dd6d2c0e-b953-a631-31b9-3993ce0902fc, identifying … <0x2b2e6680>
50 09/18/15 20:56:36.859 luup_log:138: UPnP location http://10.0.0.17:1400/xml/device_description.xml <0x2b2e6680>
50 09/18/15 20:56:36.860 luup_log:138: UPnP udn uuid:RINCON_B8E9372AC46401400 <0x2b2e6680>
50 09/18/15 20:56:36.860 luup_log:138: Unknown uuid uuid:RINCON_B8E9372AC46401400, identifying … <0x2b2e6680>
50 09/18/15 20:56:36.937 luup_log:138: UPnP location http://10.0.0.5:80/description.xml <0x2b2e6680>
50 09/18/15 20:56:36.938 luup_log:138: UPnP udn uuid:2f402f80-da50-11e1-9b23-00178818e57f <0x2b2e6680>
50 09/18/15 20:56:36.938 luup_log:138: Unknown uuid uuid:2f402f80-da50-11e1-9b23-00178818e57f, identifying … <0x2b2e6680>
50 09/18/15 20:56:36.952 luup_log:138: UPnP location http://10.0.0.212:49153/setup.xml <0x2b2e6680>
50 09/18/15 20:56:36.952 luup_log:138: UPnP udn uuid:Lightswitch-1_0-221345K1300996 <0x2b2e6680>
50 09/18/15 20:56:36.953 luup_log:138: Unknown uuid uuid:Lightswitch-1_0-221345K1300996, identifying … <0x2b2e6680>
50 09/18/15 20:56:37.005 luup_log:138: Device type is urn:Belkin:device:lightswitch:1 <0x2b2e6680>
50 09/18/15 20:56:37.006 luup_log:138: Device http://10.0.0.212:49153/setup.xml is a D_WeMo1_Controllee1.xml <0x2b2e6680>
50 09/18/15 20:56:37.006 luup_log:138: Device http://10.0.0.212:49153/setup.xml is called Front Porch Light and has serial Number 221345K1300996 <0x2b2e6680>
50 09/18/15 20:56:37.008 luup_log:138: Noting details of unknown device uuid:Lightswitch-1_0-221345K1300996 <0x2b2e6680>
50 09/18/15 20:56:37.008 luup_log:138: UPnP location http://10.0.0.10:8060/ <0x2b2e6680>
50 09/18/15 20:56:37.009 luup_log:138: UPnP udn uuid:01091048-6c00-1051-80f6-000d4bbf7e45 <0x2b2e6680>
50 09/18/15 20:56:37.009 luup_log:138: Unknown uuid uuid:01091048-6c00-1051-80f6-000d4bbf7e45, identifying … <0x2b2e6680>
50 09/18/15 20:56:37.030 luup_log:138: UPnP location http://10.0.0.210:49451/luaupnp.xml <0x2b2e6680>
50 09/18/15 20:56:37.031 luup_log:138: UPnP udn uuid:4d494342-5342-5645-0000-000002164561 <0x2b2e6680>
50 09/18/15 20:56:37.031 luup_log:138: Unknown uuid uuid:4d494342-5342-5645-0000-000002164561, identifying … <0x2b2e6680>
50 09/18/15 20:56:37.658 luup_log:138: UPnP location http://10.0.0.1:8200/rootDesc.xml <0x2b2e6680>
50 09/18/15 20:56:37.658 luup_log:138: UPnP udn uuid:4d696e69-444c-164e-9d41-e4f4c60d1422 <0x2b2e6680>
50 09/18/15 20:56:37.659 luup_log:138: Unknown uuid uuid:4d696e69-444c-164e-9d41-e4f4c60d1422, identifying … <0x2b2e6680>
50 09/18/15 20:56:37.680 luup_log:138: UPnP location http://10.0.0.20:8060/ <0x2b2e6680>
50 09/18/15 20:56:37.680 luup_log:138: UPnP udn uuid:015de0c9-0001-1064-80d3-b83e59d55453 <0x2b2e6680>
50 09/18/15 20:56:37.681 luup_log:138: Unknown uuid uuid:015de0c9-0001-1064-80d3-b83e59d55453, identifying … <0x2b2e6680>
50 09/18/15 20:56:37.694 luup_log:138: UPnP location http://10.0.0.211:49153/setup.xml <0x2b2e6680>
50 09/18/15 20:56:37.695 luup_log:138: UPnP udn uuid:Lightswitch-1_0-221345K1300F9D <0x2b2e6680>
50 09/18/15 20:56:37.695 luup_log:138: Unknown uuid uuid:Lightswitch-1_0-221345K1300F9D, identifying … <0x2b2e6680>
50 09/18/15 20:56:37.743 luup_log:138: Device type is urn:Belkin:device:lightswitch:1 <0x2b2e6680>
50 09/18/15 20:56:37.743 luup_log:138: Device http://10.0.0.211:49153/setup.xml is a D_WeMo1_Controllee1.xml <0x2b2e6680>
50 09/18/15 20:56:37.744 luup_log:138: Device http://10.0.0.211:49153/setup.xml is called Kitchen Island Light and has serial Number 221345K1300F9D <0x2b2e6680>
50 09/18/15 20:56:37.745 luup_log:138: Noting details of unknown device uuid:Lightswitch-1_0-221345K1300F9D <0x2b2e6680>
50 09/18/15 20:56:37.758 luup_log:138: Sleeping for 300 seconds <0x2b2e6680>
