[quote=“johnes, post:16, topic:186260”]Thanks… I’ll try the multimeter aspect in the AM.
No, I haven’t pinged the telguard rep. After a couple of calls with them, I am completely turned off by them:
- This product has been available for weeks now and they have no idea a) what it is, b) they havent been able to play with it, c) they don’t want to be in the business of supporting end users.
- I really want to like this thing, but telguard doesn’t have the mindset to put out a device. It’s clear that it’s half-baked, the way it appears in the UI speaks tons to me, but that’s really minor. The fact that the customer rep told me a bunch of times that they can only support security companies, that the product only works with security systems. Huh.
I mean, I was explaining what zwave was to them.
Anyway, it seems that this might be a simple elect. issue, so I’ll play with it tomorrow and see if I can’t figure it out. Really appreciate the help, tips, and ideas.[/quote]
Wow, I really should check this forum more frequently.
No defense for our initial support, your call and our clumsiness was heard loud and clear and everyone is getting better trained on the helping troubleshooting the unit. We partnered with Fortrezz to develop our idea into a device so the Z-Wave wasn’t half-baked. It is a focused effort to turn the Mimolite and Sirens into a UL listed GDO. It is true, that we primarily support security dealers with our telephone support. While we make sure everyone is more trained on the details of the product… consider this: how may other Z-Wave manufacturers could you reach 24x7 to ask for assistance. Sure, it wasn’t good out of the gate, and we’re fixing that; however, given you were literally the first call we received on it, we should get some points for having more than an email address or a never-to-be-returned voice mailbox.
Now, on the UI. This device is a binary switch (on-off) class pure and simple. The benefit is that it will add GDO control to essentially any device that supports switches. The downside is that you are stuck with on-off lingo. I have posted the JSON files in another thread to make the GDC1 look like a garage door with Open-close and other manufacturers are adding native open-close for this device to their UI’s. Honestly, I have five of GDC1’s connected to my single garage door and through automations-- automatic closings, open and close on geo-location, open and close with car ignition status, etc.–I never use the UI and imagine that the On-Off will rarely be seen after the first couple of days. My garage door opens when I turn my car off at home, always closes 10 minutes after it opens during the work week and closes anytime a member of my family leaves the neighborhood. It is fully automagic. There is no need to ever access the app/UI once tapped into automations.
Now to the potential issues with your system.
- First make sure that your GDO supports third party products with one of two methods.
1a) Read the GDO manual. If you have a LiftMaster, Chamberlain or Sears product that touts Security+ 2.0 then you are out of luck with any product other than the MyQ ones (for now… more on this later). S+2.0 is an encrypted serial protocol that only works with Security+ 2.0 wall consoles. The net effect of connecting any relay-based control is that nothing happens. The Chamberlain manual actually says that their own non-S+2.0 products and third party products won’t work in the section about connecting the wall console.
1b) Use bare wires in the GDO’s connection and short them. If the door moves then the GDO is compatible with the GDC1, etc., but if it doesn’t move it is likely a 1a issue.
- Don’t mess with the jumpers! You should only have JP7 shorted. Removing this reverts it back to older development logic and I don’t know what happens. The other jumpers are there for test, etc. This is why we don’t include the jumpers for the other pins because they don’t do anything but screw it up if you mess with them.
- Recognize that for 30 seconds after a Z-Wave command is received and you hear the “click” of the GDC1 relay, It will ignore further commands because it is waiting for the GDO to close/open. Patience is a virtue here or you’ll drive yourself nuts wondering why all your Mortal Kombat button mashing is doing no good.
At this point, let me pause and have you email me back what you are seeing after the above things are verified. I will review this full chain to see if there is another tidbit I can help with as I haven’t had the opportunity to cull through the full post.
Best regards,
Shawn Welsh
