Getting error trying to update Device info DB
Seeing this in reactor UI:
A newer version of the device information database is available. Please use the update function on the Tools tab to get it. This process is quick and does not require a Luup reload or browser refresh–you can immediately come back here and go right back to work! The new version is 865.877, and you are currently using 557.352…
Hit update in Tools and get an error: “The update could not be retrieved. If this problem persists, consult the documentation.”
Looked through logs and not seeing anything specific. You have a keyword I should search for?
Same here, just tried again.
EDIT, oops and now I got this on the activities tab:
Waited and switched tabs as suggested, but so far that did not help.
Update:
rebooted my Vera, error was gone and the DB could be updated this time.
