Is their a way through the VeraLite interface to get a light to remember its last dimmer position and revert to that position when switched on again. The AutHomationHD app does it, but wondered if the VeraLite interface did it also?
No, this is only a feature of my app and not one that is built into Vera. There may be ways around this, e.g. using the Variable Container plugin and PLEG.
- Garrett
Yes, I found that my app does it perfectly. What is the Variable Container plugin and PLEG you refer to?
