In an existing home network setup I have my router set up with Dynamic DNS and I forward port 80 to a web server and another port to my router itself for remote management.
I added Vera to the network with a fixed IP address and had to change the forwarding on the router for port 80 to vera in order to see the control interface. I set Vera’s firewall as off in Switch mode.
My router is a netgear and does allow me to change the port number in the forwarding, only to forward the same port to a different IP.
How do I effectively get Vera to listen on a different port for http? I looked into the Advanced network settings and the port forwarding there seemed like it should allow be to forward and change ports but I think the UI is broken as there’s no place to specify 2 port numbers even though the help/docs would suggest there is. If that worked then I could enable the firewall and Vera would forward the port to itself?
Am I going about this in the wrong way - I just want to access Vera from a specific (non “80”) port number behind my existing router.
Thanks,
Neilios
