I wonder if it is possible to get Vera Alert to send the temperature from indoor / outdoor sensor, for example at 12:00 every day to my Androide phone?
Can someone explain to me how I can achieve this?
Appreciate the input
Frode
Frode
You would have to create a scene. (This can also be done as an additional condition with the PLEG plugin).
On the scedules tab … set a time to run the scene on your desired scehedule.
On the advanced tab for the scene … Add the Vera Alerts device. SendAlert Action
For the message use:
Outside temp: {device([XX]service[urn:upnp-org:serviceId:TemperatureSensor1].CurrentTemperature)} Inside temp: {device([YY]service[urn:upnp-org:serviceId:TemperatureSensor1].CurrentTemperature)}
Where XX is the device ID for the outside temperature sensor, and YY is the inside temperature sensor.
Awesome, it works fine.
Thank you.
Frode
[s]Pardon me to digg up a old thread Ricard.
Setting up a disable alarm scene would this be possible?
TTS Message to phone and tablet.
“Welcome home ‘name’, alarm has been disabled, your home is 20 degrees”
With the 20 being a variable from a temperature device[/s]
Welcome home james, the alarm has been disabled and your home is {device([61]service[urn:upnp-org:serviceId:TemperatureSensor1].CurrentTemperature)} degrees {tone:tts}
Works nicely, google lady needs a sexier voice imo …
